July 30, 2014
High Permeability Materials
Click here to go to our main materials page
Click here to go to our magnetic materials page
Click here to go to our skin depth page
Click here to go to our page on conductivity
Here's some sites that provide tables of high permeability materials, thanks to Mark:
http://www.kayelaby.npl.co.uk/general_physics/2_6/2_6_6.html
http://wapedia.mobi/en/Permeability_%28electromagnetism%29#5
Special case: high permeability metals
Relative permeability refers to a material's ability to attract and conduct magnetic lines of flux. The more conductive a material is to magnetic fields, the higher its permeability. Most materials have High Permeability MaterialsR near 1, including copper, and gold. The exceptions are nickel, iron, etc. Permeability of most metals is 1.0. However, metals such as nickel are a special case, and can have permeability as high as 100 or more. Permeability is a magnetic property of a material, and is often expressed as High Permeability Materials0 x High Permeability MaterialsR, where High Permeability Materials0 is a physical constant equal to exactly 4*pi*10-7 Henries/meter and High Permeability MaterialsR is the relative permeability. High Permeability MaterialsR is equal to one for free space, and a whole lot of other materials including gold and copper. The metals that are notable exceptions are nickel, cobalt, maganese, chromium and iron, which are called ferro-magnetic materials. While we're on the subject, if anyone knows where we can obtain reliable info to construct a table of permeabilities of different materials, please send it in and win a Microwaves101 pocketknife! Speaking of which, the following was provided by Stephen D. Winchell, a physicist working at United States Naval Academy:
"I was looking for some further information on permalloy because another ferromagnetics researcher has used it in some eddy current field experiments and I stumbled upon your page. I am currently working as a physicist, on eddy current research in bulk ferromagnetic materials. The question about a table of permeabilities is actually, depending on how in depth you want to answer it, a very fascinating question. Now, diamagnetic and paramagnetic materials are quite boring in terms of permeability (like 10-5 - 10-3) but ferromagnetic materials are totally different. It depends on many many factors like annealing and crystalline structure, but typically, for all ferromagnetic materials we measure permeabilities between 1 and 10000 or more, depending on their magnetic state (which is a function of its history and applied field). when you look at a ferromagnetic hysteresis curve you can see (whether its in B(H) or M(H)) that the rate at which the material responds to external fields is in fact totally nonlinear (I believe the best description of it currently is a piecewise exponential "cooperative" element and an extrapolated virgin curve "anisotropic" element.) Ferromagnetism is very complex because of grain and domain cooperation and exchange interaction between atoms... so the answer is that there are functions which, with some accuracy, describe permeability as a function of applied field, but there are no tables that give an answer. In the steel I work with I have measured permeabilities from about 10 to about 10000 as I move through a hysteretic cycle."
Thanks for the help, from another Steve! Looks like we won't try to hold a breath on providing such a table...
The problem with nickel plating
As Wally pointed out in the above story, if you have nickel plating as your first metalization in the microstrip conductor, it is unlikely that overplating it with thick gold will fix your RF loss problems. Nickel is one of the worst conductor metals you can use, for reasons described below.
Looking up the bulk resistivity of nickel you'll see that it isn't that much worse than copper or gold, perhaps three time the resistance. However, looking back at the skin depth equation, note that High Permeability Materials0 x High Permeability MaterialsR is buried in the denominator. This is what causes trouble. Check this out: nickel has a bulk resistivity of 8.7 versus gold at 2.44, so you'd expect it to have maybe three times as much loss if you plate up to the rule of thumb of five skin depths. WRONG! The maximum conductivity of a nickel thin film is about 3% of what you'd get with gold. This is because the skin depths are much thinner due to the relative permeability term, which is often reported at 100 for nickel. There are good reasons that manufacturers want to use nickel plating, it has excellent adhesion to ceramic surfaces, and it is a good barrier metal in some solder schemes. However, putting a layer of nickel down first in any plating scheme is about the worst thing you can do to a substrate from an RF loss point of view.
EMI enclosures
When is a high-permeability material a good thing for microwaves? When when trying to shield from electromagnetic interference (EMI), especially at low frequencies where the skin depth is greater, a high permeability metal will kill off the fields before they penetrate your module. High magnetic permeability gives an ability to absorb magnetic energy. Mumetal® (say moo-metal or mew-metal, it is pronounced both ways), and Permalloy® are trade names of materials that are designed for high permeability. They are alloys of iron and nickel. Permeability is as much a property of the material's grain structure as it is a bulk property. Thus the secret recipes for high-permeability metals include proprietary annealing. Check out Magnetic Shield Corporation for more info on this subject.
